Disallows a VLAN to be placed in the UP state without an external active port. This allows (disallows) the VLANs routing interface to become active.
| vlan_name | Specifies a VLAN name. |
| vlan_list | Specifies a VLAN list of IDs. |
N/A.
Use this command to specify a stable interface as a source interface for routing protocols. This decreases the possibility of route flapping, which can disrupt connectivity.
The following example disallows the VLAN accounting to be placed in the UP state without an external active port:
disable loopback-mode vlan accounting
The vlan_list option was added in ExtremeXOS 16.1.
